Hello guys,
when I import parcels from civil 3d to infraworks as coverage area with too many vertexes, I want the imported parcels to be in a graded shape, but with all these vertexes I can't modify the elevation of each vertex. does infraworks has an option to modify all vertexes based on 1st and last vertexes elevation? thanks to all.
If it's a coverage area, you have the option of moving all the vertices at once. If you right-click, choose Shape Terrain. Then you can move the arrow up or down to adjust the height. This will then grade down to natural ground.
