Import typical section from Civil3D
Hello everybody,
i hope all of you are doing well!
I went to AU2016 Las Vegas last week and I got the possibility to meet the most interesting people ever.
My mind was blowing for so many inputs! It was great! So I came up with an idea.
Would it be possible to import the typical section that we create in Civil3D into IW360?
The idea is to create a common library between the two, because IW360 has some limitations in this regard.
For example have a look at the images below. In a dashed line you can see the existing surface, in the continuous line you can see the proposed road.
Then you will find vertical alignment and horizontal alignment, with the corridor in pink.
Since we can recreate this section with subassemblies, horizontal alignment and vertical alignment (I am at your disposal to go deeper into this) to create a corridor, I would love to import this library of typical sections into IW360.
I am at your disposal for further clarificaitons.
Best regards
Nicola
1 Comment
gchakri
Status changed to: Gathering Support
Thanks for the idea Nicola! Our InfraWorks colleagues will reach you out on asking more details around this fir sure.
Others could you please weigh in on this and/or vote on the idea?
