I have found a video that suggests there should be a tab for grading at the bottom of the Style Palette. It doesn't show up in on mine. I don't suppose anyone has any suggestions as to why? We want to manipulate the gradients.
Solved by BarrieSharp. Go to Solution.
Hi @BarrieSharp,
which version of IW are you using on your machine?
Best
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Hi @BarrieSharp,
I downloaded and installed the same version you have, and everything is working properly as you can see from the image below.
Is that the only palette missing?
Best
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Hi @BarrieSharp,
http://help.autodesk.com/view/INFMDR/ENU/?guid=GUID-0B9D9B76-6DCC-449A-A12B-D316DCF5D1F2
And you will find my palette attached.
You just have to load it into the Catalog, it is the same that you have seen in the image
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Hi @BarrieSharp,
it does not allow me to attach a .json file.
You will find it here, just unrar it and load it.
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Thank you very much for your efforts. I used the import on the JSON you supplied but the tab failed to turn up. I explored the program folder structures to see if there was anywhere it could be placed manually. Through my trials I kept closing and reopening the software and stumbled upon the solution. The home page has a toggle to preview the grading tools.
Thank you very much for your efforts. I used the import on the JSON you supplied but the tab failed to turn up. I explored the program folder structures to see if there was anywhere it could be placed manually. Through my trials I kept closing and reopening the software and stumbled upon the solution so your reply did help.
The home page has a toggle to preview the grading tools. That has made the tab appear.
Hi @BarrieSharp,
So it works correctly now?
Glad the solution was found. You can mark it as a Solution, so others will easily identify the issue and how to solve it.
Best
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
