In AIMS 2014's Basic layout's search function have the below:
1. User enter text in the Task Pane's search input box.
2. User get back with search result.
3. User click's the items from the search result.
4. The item or feature is selected in the map.
5. The map is zoomed to the selected feature.
In AIMS 2015's Basic layout's search function have the below:
But the map is not zoomed to the selected feature. I think that part of functionality is overlooked in AIMS 2015's Basic layout.
I think it will be grate if that functionality is available inside the Search function of AIMS 2016 release.
Thanks in advance.
Best Regards
Mohammad
Solved by gluckett. Go to Solution.
This is related to a post by Daniel Du in the Developer forum.
Just copy the attached file and replace the same file it in the following folder:
C:\Program Files\Autodesk\Autodesk Infrastructure Web Server Extension 2015\www\viewerfiles\ajaxmappane.templ
your zooms should work.
