Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Wrong WMS setting
2 REPLIES 2
kalman_albert
657 Views, 2 Replies
Wrong WMS setting
Can tell somebody if we can change the wrong setting in AIMS 2013/2014. WMS service is not work.
The instaltion is for IIS, the mapguide works but not the WMS service.
The service if is teste in /mapagent/index.html works but is not possable to conenect in AIMs or Map
Albert
"Nothing will ever be as it was!"
2 REPLIES 2
jackie.ng
in reply to: kalman_albert
Double check that your SERVER_NAME item under the <your AIMS install>\<Server>\Wms\OgcWmsService.config.awd file actually contains the updated setting.
- Jackie
I have Mapserver2014 install on IIS and on c:\
I have MapGuide opensource2.4 on Apache 8008 port and on d:\
but  'http://192.168.0.111:8008/mapguide' use mapserver2014 services
 'http://192.168.0.111/mapserver2014/mapadmin/about.php' get:
About Infrastructure Map Server - Site Administrator
Infrastructure Map Server (Version 2.5.1.7601)
Infrastructure Map Server - Site Administrator (Version 2.5.1.7601)
and
 'http://192.168.0.111:8008/mapguide/mapadmin/about.php' get:
About MapGuide Site Administrator
MapGuide Server (Version 2.5.1.7601)
MapGuide Site Administrator (Version 2.4.0.6876)
why the server is the same?
Can't live together mapserver2014 and MapGuide Opensource. After installing 2014 this alter MGO 2.4 settings ?
Albert
