Infrastructure Map Server Developer
Contributor bzc
bzc
Message 1 of 3 (301 Views)
Wish List
301 Views, 2 Replies
09-16-2002 12:04 AM
Wouldn't it be great if future releases of MapGuide exposed an API object model for creating mwf files on the server? This should be out of the box functionality. Intergraph does this very successfully with WebMap. They provide programmatic access on the server side by exposing all the methods, properties and objects used to create maps. This gives you tons of options including on the fly flexibility to create maps tailored to the viewer. By doing this you can react to user input and generate dynamic maps...not static authored maps.
*Andrey, Krasnokutski
Message 2 of 3 (301 Views)
Re: Wish List
09-16-2002 12:30 AM in reply to: bzc
Use Dinamical Autoring Toolkit. XML it's more
flexible.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Wouldn't
maps.
Active Member
pian2000
Message 3 of 3 (290 Views)
Re: Wish List
01-03-2011 06:21 PM in reply to: bzc
1. It is greatful if mapguide can provide us better interface like esri does in their arcgis server version 10. They make full use of the flash technology and give the user interactive and friendly view.
2. My company involve in data interoperabillity project and most of the data that we use now is in multiple format like .shp, .tab and .gdb. It is much better if autodesk mapguide can provide a interoperability module that read the style, scalling, colour etc in various software. This will improve out timeand eneggy to do all those thing which is consume a lot of time and concetration.
3. Connection to multiple format need an OGC standard and the standard that we use is OGR to connect to .TAB file. But we facing a problem when to print the map using printing module from mapguide. The symbol is not according to what we set in the mapguide. It id greatful if mapguide can provide flexible format for printing.
