Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Windows 2008 Server installation problem
2 REPLIES 2
accessmayank
495 Views, 2 Replies
Hi All,
I am trying to install MGE on windows 2008 server. {color:#000000}Mapguide{color} Server has been installed successfully and I can also access the server administration page from remote machines. But when I try to connect MapGuide Studio with the server, it gives the following error.
{color:#ff0000}See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Length cannot be less than zero.
Parameter name: length
at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
at Autodesk.MapGuide.Studio.Site.UI.SiteExplorer.ExtractMessageFromException(WebException ex)
at Autodesk.MapGuide.Studio.Site.UI.SiteExplorer.HandleError(Control messageBoxOwner, Exception e)
at Autodesk.MapGuide.Studio.Site.UI.SiteExplorer.treeViewRepository_BeforeExpand(Object sender, TreeViewCancelEventArgs e)
at System.Windows.Forms.TreeView.OnBeforeExpand(TreeViewCancelEventArgs e)
at System.Windows.Forms.TreeView.TvnExpanding(NMTREEVIEW* nmtv)
at System.Windows.Forms.TreeView.WmNotify(Message& m)
at System.Windows.Forms.TreeView.WndProc(Message& m)
at Autodesk.Gis.Forms.MultiSelectTreeView.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Studio
Assembly Version: 2.0.0.3202
Win32 Version: 2.0.0.3202
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Studio.exe
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Autodesk.MapGuide.Studio.Locale
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.MapGuide.Studio.Locale.DLL
msvcm80
Assembly Version: 8.0.50727.1434
Win32 Version: 8.00.50727.1434
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.1434_none_d08b6002442c891f/msvcm80.dll
Autodesk.MapGuide.Studio.UI
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.MapGuide.Studio.UI.DLL
Autodesk.Gis.DwfToolkit
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.Gis.DwfToolkit.DLL
Autodesk.MapGuide.Studio.Feature
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.MapGuide.Studio.Feature.DLL
Autodesk.MapGuide.Studio.FdoLoader
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.MapGuide.Studio.FdoLoader.DLL
Autodesk.Gis.Forms
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.Gis.Forms.DLL
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.MapGuide.Studio.Site.UI.DLL
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.MapGuide.Studio.Site.DLL
Autodesk.Gis.ObjectModels.LayerDefinition-1.2.0
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.Gis.ObjectModels.LayerDefinition-1.2.0.DLL
Autodesk.MapGuide.Studio.MdfModel
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.MapGuide.Studio.MdfModel.DLL
Autodesk.MapGuide.Studio.ImageEngine
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.MapGuide.Studio.ImageEngine.DLL
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
OSGeo.FDO
Assembly Version: 3.3.8070.0
Win32 Version: 3.3.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/OSGeo.FDO.DLL
Autodesk.Gis.UI.ExpressionEditor
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.Gis.UI.ExpressionEditor.DLL
Autodesk.Gis.StylePreview
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.Gis.StylePreview.DLL
Autodesk.MapGuide.Studio.Load
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.MapGuide.Studio.Load.DLL
Autodesk.MapGuide.Studio.Load.Serializer
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.MapGuide.Studio.Load.Serializer.DLL
Autodesk.MapGuide.Studio.Dwg.Load
Win32 Version:
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.MapGuide.Studio.Dwg.Load.DLL
Autodesk.MapGuide.Studio.UIContext
Assembly Version: 0.0.0.0
Win32 Version:
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2009/Autodesk.MapGuide.Studio.UIContext.DLL
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
yzse3nlj
System.Web
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
pi3cj_u2
yeebzbu1
inebqht1
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
{color}{color:#000000}I think it is something to do with the .NET but no idea how to resolve the problem. Is it a compatibility issue or something else?
Please reply if anyone has any idea.
Mayank{color}
2 REPLIES 2
georgega
in reply to: accessmayank
I'm having the same issue now. Did you find a resolution? I'm using Server 2008 and IIS 7.5. Can you run the phpinfo.php test? The Site Admin works for me but when I try to run the phpinfo.php test, I get a http 500 internal server error.
georgega
I got mine resolved. I got a new serial number and license file from Autodesk, reinstalled MGE and the Web Extentions, stopped and started the License Manager, reread the License FIle, started lmgrid.exe and then restarted the MapGuide Enterprise service. After all of that, the Unhandled Exception error disappeared from Studio.
