Infrastructure Map Server Developer
Valued Contributor
swimming123
Message 1 of 4 (1,250 Views)
widget not display in the Toolbar
1250 Views, 3 Replies
06-05-2012 09:18 AM
I try to create a JS, xml file and copy to the right location under fusion/widgets folder; Added the widget into ToobarVertical, but the widget did not show. Probaly something wrong. Anyone can give me some suggetion?
Valued Mentor
jackie.ng
Message 2 of 4 (1,245 Views)
Re: widget not display in the Toolbar
06-05-2012 07:16 PM in reply to: swimming123
Did you declare the appropriate widget in your the WidgetSet portion of the Flexible Layout document?
- Jackie
Valued Contributor
swimming123
Message 3 of 4 (1,244 Views)
06-05-2012 07:37 PM in reply to: jackie.ng
I just use the InvokeURL widget (js and xml) and modified it. because I need create a point layer using OpenLayer, then pass the lot/lat value of point to server side and do the query. So I delete the selection part, binded the digitize a point function with the widget. I didn't check the WidgetSet part in ApplicationDefinition file. Is this the right way?
Active Member
lrodriguez84
Message 4 of 4 (1,219 Views)
07-02-2012 11:29 AM in reply to: swimming123
Hi, i did something similar. I created a widget to invoque js from this i did a http request to server and the server side (C#.net) response the result that i wanted.
