Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
why do'nt select some point ?
2 REPLIES 2
235 Views, 2 Replies
hi ,
I have a point layer that DataSource is OLE DB , When i Select this layer by Select/Polygon some of the point don't select !!!!
Why ?!!! it select some of them !!!
2 REPLIES 2
The reason for this could be ; there might be duplicate points.
i mean there could be two points sharing the same location.
Check out this spadana.
Thank you, you're right , Some point have the same location .
