Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
what's the API function for distance query
1 REPLY 1
swimming123
1287 Views, 1 Reply
Hi there,
MapGudie has MeasureGreatCircleDistance(coord1, coord2) and MeasureEuclideanDistance(coord1, coord2) to calculate the distance between 2 points. What if I want to query the shortest and longest distance between one point and one layer which has one million points? Is there any API I can use? What's the solution I can use? Thank you
1 REPLY 1
Daniel.Du
in reply to: swimming123
Unfortunately, there is no APIs for topology like finding shortest path in MapGuide, you need to implement yourself.
Daniel Du
Developer Technical Services
Autodesk Developer Network
