Infrastructure Map Server Developer
Valued Contributor
swimming123
Message 1 of 2 (1,095 Views)
what's the API function for distance query
1095 Views, 1 Replies
07-26-2012 08:04 AM
Hi there,
MapGudie has MeasureGreatCircleDistance(coord1, coord2) and MeasureEuclideanDistance(coord1, coord2) to calculate the distance between 2 points. What if I want to query the shortest and longest distance between one point and one layer which has one million points? Is there any API I can use? What's the solution I can use? Thank you
Board Manager
Daniel.Du
Message 2 of 2 (1,035 Views)
Re: what's the API function for distance query
08-27-2012 02:10 AM in reply to: swimming123
Unfortunately, there is no APIs for topology like finding shortest path in MapGuide, you need to implement yourself.
Daniel Du
Developer Technical Services
Autodesk Developer Network
