Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
WGS84.Psuedo Mercator Coordinate System
1 REPLY 1
shobyshah
1090 Views, 1 Reply
I can not find this projection in World/Continental coordinate system. Where can i find this.
thanks.
shobyshah
Tags (1)
1 REPLY 1
jackie.ng
in reply to: shobyshah
Are you sure you're not seeing this?
As an aside, this dialog is woefully inefficent for looking up coordinate systems. It should be the same dialog as in AutoCAD Map.
- Jackie
