Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Viewer in Mapguide Studo 2011
4 REPLIES 4
PascalFRANCOIS6037
643 Views, 4 Replies
While connected whith an non administrator account on the server (windows 2008 SP2), nothing appears when I ask for a preview in Mapguide studio 2011 (Basic Web Layout Mode).
It works all right with an administrator account.
How can I fix that problem ?
4 REPLIES 4
Is it possible anonymous access is disabled under IIS?
Dave
Hello Dave,
Thanks for your reply
The anonymous access is enabled under IIS. I have no idea of what is wrong.
Christine
When you say it doesn't work under a non-administrator account do you mean:
1) I try using Anonymous as the account to log into the viewer and it doesn't work
2) I am logged into the Windows with a non-admin account and in the browser I get nothing back regardless of what login I use for the MGE viewer
If it's the latter it's some kind of Windows security issue.
If it's the first are you using .NET or PHP? Can you preview a flexible layout as that uses PHP?
Dave
My problem is actually  the second option :
I think too that it's a windows security issue but I could not fix it. Can Anybody help me with that problem ?
Christine
