i want to use the multiple map toggle in AIMS 2012. All four maps have the same inital view and the same coordinate systems. But sometimes (not allways!) i get the following error:
Fusion Error:
AppDef initial view is outside map maxExtent, resetting initialView to maxExtent
How can i solve this problem?
regards,
sk
You can probably just remove/comment the line that raises this error message. There's no real reason I can think of that makes this an error-worthy thing to raise an error about.
- Jackie
I've allready found this suggestion of yours in OSGeo Fusion forum. But when i rebuild fusionSF and fusionSF-compressed after commenting this error out, fusion doesnt work anymore (map and widget are not shown)...
