Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
83 Views, 1 Reply
Users
How can I dissalbe password entry for viewing map over the internet?
http://gis.dalmacija.hr/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fCeste%2fWeb+layouts%2fCesteWL.WebLayout&LOCALE=hr
requires password.... in Mapguide admin I did not found any user management
that is connected with particular project, only general users ang groups....
1 REPLY 1
dswilson
If you are just opening a web layout you defined in Studio, you can pass an undocumented parameter at the URL to get around this. Append &USERNAME=Anonymous to the URL. If you want to use a different username that has a password you can also append &PASSWORD= to the URL.
You could alternatively modify the mainframe.php/.aspx/.jsp file found under your webserverextensions/www/mapviewerxxx folder depending on your API language. You could modify the username variable at the top of the file and set it to Anonymous.
Dave
