Show only
Search instead for
Dear all
I'm trying to load map in mapviewe, I attached the code I've wrote.
my problem is as follow, I want to use a variable to set its URL property instead of Initial it with a static value. Could any one help me please?
Please, same here but for .NET. I've tried in different ways but couldn't resolve it. The variable is in the codebehind and I want to call it from the param value.
Any suggestions?
Thanks in advance!
Generally, scripts dynamically generate HTML on the server-side and feed the resulting static HTML to the client's browser. What you need to do is to modify the URL while the script is dynamically generating the HTML before it is sent to the client's browser.
It is what my example code did. In the case of a IIS web server + PHP setup, the IIS webserver notices the client's request for the web page, feeds the requested ".php" file to the PHP processing module, which executes all the PHP code and generates a HTML that IIS finally delivers to the client's browser. The process for IIS + .NET should be similar.
