There is a problem in AIMS 2014 under Redline Function.
The problem is that it can not upload Redline (tested with SDF file: The SDF file is generated by Redline Widget itself).
I think the problem is on the below line:
$bs = new MgByteSource($_FILES["UPLOADFILE"]["tmp_name"]);
on markupmanager.php file under UploadMarkup function.
After uploading it shows the below on taskpane:
Error
The specified file was not found:
Any help will be appriciated.
Thanks in advance.
Best Regards
Mohammad Amin
