Wishlist: Unmanaged DWG support LINK TEMPLATE/OBJECT DATA/BLOCK ATTRIBUTES.
Currently you have to:
- Load the DWG with OD or LT etc
- Export the data configuration file using MapGuide Maestro
- Connect to the DWG using Unmaged Alias
- Paste in the configuration DWG in the Alias
It would be good not to have to do this.
