Infrastructure Map Server Forum
Welcome to Autodeskā€™s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Showing results forĀ
Did you mean:Ā
Unable to display SHAPE file in AUTHOR
2 REPLIES 2
cyj-1
1304 Views, 2 Replies
I have a polyline shape file, which can be view
in ARCVIEW.
I add the layer to AUTOR. There is no any error in
the progress. But the map can't be displayed.
Are there any other special setting in AUTHOR?
2 REPLIES 2
in reply to: cyj-1
Make sure the coordinate setting of the
shape file is the same as is set in MG Author.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
in ARCVIEW.
I add the
be displayed.
AUTHOR?
in reply to: cyj-1
Actually, you must insure that the SHP
Datasource (in the Autodesk MapGuide Server) for the SHP file in question is set
up with the same CS as the data.
Then, if a different CS is set in the MWF
(Autodesk MapGuide Author) the data will be transformed correctly by the
server.
Chris L. Amos
Autodesk MapGuide Quality
Engineering
I
in ARCVIEW.
I add the
be displayed.
AUTHOR?
