Infrastructure Map Server Forum
Welcome to Autodeskā€™s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Showing results forĀ
Did you mean:Ā
The User ID or Password is invalid. Please try again!
1 REPLY 1
1169 Views, 1 Reply
i have a problem if I connect to the MapGuide Server using MapGuide Studio.
I get this error:
"The User ID or Password is invalid. Please try again!"
I use this adress to connect:
http://localhost/mapguide2011
with the user:
Administrator
and the password:
admin
If I connect using Maestro I got the error:
"unauthorized"
The system ist:
- Windows 7 x86 Ultimate (english version)
- .NET 4.0
- MapGuide 2011 Enterprise x86 (german version)
- MapGuide 2011 Update 2
The MapGuide Server is using a IIS configuration with .NET. My application which is using MapGuide is running and the site administrator, too.
I canĀ“t only connect to the server by using studio or maestro.
On the system php is not installed.
Any solutions?
Highscreen
1 REPLY 1
Daniel.Du
Please make sure you are using .net framework 2.0 for your application pool of MapGuide. it may be 4.0 by default if you installed .net framework 4, while MapGuide has not been upgrade to 4.0 yet.
Daniel Du
Developer Technical Services
Autodesk Developer Network
