Hi All,
ServerActivator does not start also while login to studio encounter below error message:
The remote server returned an error: (559) MgInvalidLicenseException.
at Autodesk.MapGuide.Studio.Site.Comm.RequestManager.CreateSession()
at Autodesk.MapGuide.Studio.Site.Comm.RequestManager.InitializeSession()
at Autodesk.MapGuide.Studio.Site.SiteManager.InitializeRequestManager(String siteString, NetworkCredential credential, RequestManager rm, String& siteVersion, Exception& unKnownError)
Any help on this please?
Is this a Map 3D question or a MapGuide question? If Mapguide, you may get a better response on this forum:
http://forums.autodesk.com/t5/Autodesk-MapGuide/bd-p/88 (for old MapGuide)
or here:
http://forums.autodesk.com/t5/Autodesk-MapGuide-Enterprise/bd-p/233 (for new MapGuide)
Norm
Actually, it is license activator which is not coming up. Hence, I am not able to activate license as well.
Any idea on this please.
Please note that, I have reinstalled the AutoDesk Infrastrcuture Map Server 2012 again but issue remains as it is.
@TATA_JUNE2007 wrote:Actually, it is license activator which is not coming up. Hence, I am not able to activate license as well.
Do you have the license manager installed and running property? Do you have the license file(s) from Autodesk?
Check if your MapGuide Server is On or Off. Make sure turn it on, the error will gone.
Sir,
Good day! Our AIMS 2013 is already activated and turned into full version but suddenly this error came up after restarting server:
Thank you.
-mark
Hello Sir,
Good day! We have already restarted the AIMS 2013 service serveral times,we even restarted the physical server but still the same error persists.
This is already in activated full version then suddenly invalid license displays on the logs.hope someone has resolved this issue,will re-install of the AIMS will solve this?but we are in a tight and strict environment to re-install.
Thank you.
