Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
The remote server returned an error: (559) MgInvalidL​icenseExce​ption.
3 REPLIES 3
932 Views, 3 Replies
Hi All,
ServerActivator does not start also while login to studio encounter below error message:
The remote server returned an error: (559) MgInvalidLicenseException.
   at Autodesk.MapGuide.Studio.Site.Comm.RequestManager.CreateSession()
   at Autodesk.MapGuide.Studio.Site.Comm.RequestManager.InitializeSession()
   at Autodesk.MapGuide.Studio.Site.SiteManager.InitializeRequestManager(String siteString, NetworkCredential credential, RequestManager rm, String& siteVersion, Exception& unKnownError)
Actually, it is license activator which is not coming up. Hence, I am not able to activate license as well.
Any idea on this please.
Please note that, I have reinstalled the AutoDesk Infrastrcuture Map Server 2012 again but issue remains as it is.
OS  Windows 2003 Server with IIS 6.0
3 REPLIES 3
hence_the_name
Hi Anand,
did you try to start the License Activator? (Start>Programs>Autodesk>Autodesk Infrastructure Map Server 2012)?
What happens when you try to start it? What does " license activator which is not coming up" mean?
By the way - you mentioned that the server OS is W2003 - according to the system requirements W2008 is required.
Rob
http://raumpatrouille3d.blogspot.ch/
in reply to: hence_the_name
Rob,
When I  go Start>Programs>Autodesk>Autodesk Infrastructure Map Server 2012>Launch Autodesk Infrastructure Map Server Licensing Activator
This does not launch the license activator!
Also, I have OS Windows 2003 server. Does it okay to installed Autodesk Infrastructure Map Server 2012?
hence_the_name
Hi Anand,
have a look at Windows EventViewer - maybe further information can be found there why the serveractivator.exe doesn't start.
Not sure if this is the reason but AIMS 2008 requires W2008 as OS, not W2003.
Rob
