Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
the coordinate system initialization error
2 REPLIES 2
DEVR1930
1850 Views, 2 Replies
I am using MAPSERVER 2012 and created a map by SVY21 coordinate system. It works fine in one server and in another server i get an error like "THE COORDINATE SYSTEM INITIALIZATION FAILED. COULD NOT INITIALIZE THE GEODETIC TRANSFORMATION" i dont know how to solve this problem. I searched a lot for a solution but no luck. Please help me out.
2 REPLIES 2
jackie.ng
in reply to: DEVR1930
Do you have an existing installation of an older version of MapGuide/AIMS/AutoCAD Map?
It may be using it's (older) coordinate system dictionaries
- Jackie
DEVR1930
in reply to: jackie.ng
I am using AutoCad 2012. Only when i add few layers it shows me this error. Few layers work and other layers like buildings and road are not seen and they keep showing this error when i zoom in. These layers were copied from the exciting working server. Is there anything else i have to check because i have no clue from where the error is coming.
