I'm having trouble understanding the Text Expressions.
This Expression works as follows:
CONCAT ( CONCAT ( CONCAT ( CONCAT ( PARCEL_NUM , '\n' ), Owner_Name ), Prop_Add1 ), Prop_Add2 )
But then I want to add and enter after each field, so i put in this Expression but i get an error saying the number of arguments for function is invalid:
CONCAT ( CONCAT ( CONCAT ( CONCAT ( PARCEL_NUM, '\n'), Owner_Name , '\n' ), Prop_Add1 , '\n' ), Prop_Add2 , '\n' )
Any help would be appreciated.
Solved by plantech1. Go to Solution.
You need to concatenate each '\n' entry just like the first inside CONCAT with (PARCEL_NUM, '\n'). Each entry needs to be concatenated with the previous concatenation. Try adding three more CONCATs like:
CONCAT ( CONCAT ( CONCAT ( CONCAT ( CONCAT ( CONCAT ( CONCAT ( PARCEL_NUM, '\n'), Owner_Name ), '\n' ), Prop_Add1) , '\n' ), Prop_Add2) , '\n' )
