Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Text Expression Error??
1 REPLY 1
cloquet
1850 Views, 1 Reply
I'm having trouble understanding the Text Expressions.
This Expression works as follows:
CONCAT ( CONCAT ( CONCAT ( CONCAT ( PARCEL_NUM , '\n' ), Owner_Name ), Prop_Add1 ), Prop_Add2 )
But then I want to add and enter after each field, so i put in this Expression but i get an error saying the number of arguments for function is invalid:
CONCAT ( CONCAT ( CONCAT ( CONCAT ( PARCEL_NUM, '\n'),  Owner_Name , '\n' ), Prop_Add1 , '\n' ), Prop_Add2 , '\n' )
Any help would be appreciated.
1 REPLY 1
plantech1
in reply to: cloquet
You need to concatenate each '\n' entry just like the first inside CONCAT with (PARCEL_NUM, '\n').  Each entry needs to be concatenated with the previous concatenation.  Try adding three more CONCATs like:
CONCAT ( CONCAT ( CONCAT ( CONCAT ( CONCAT ( CONCAT ( CONCAT ( PARCEL_NUM, '\n'),  Owner_Name ), '\n' ), Prop_Add1) , '\n' ), Prop_Add2) , '\n' )
