I use Autodesk Infrastructure Map Server to publish in Autocad 2d floor plan
Many of the blocks are rotated
I used Studio to publish the blocks as symbols
When I open the floor plan in AIMS blocks are not rotated
how to solve?
Thank you for your help
Solved by kajar. Go to Solution.
Studio converts DWG data to SDF data. All block converted to symbols but without "Rotation" parameter so all block rotation remains 0.
Better(automatic) way to upload floor plan is directly from MAP 3d, then all text, block rotatian remains like in DWG file and also all styling is included.
Second way is to manually export DWG objects to SDF, all you have to is add Rotation parameter to blocks during conversion.
In Studio you have to style those features with Rotatation parameter using expression. like this ( 180.0 * ( ROTATION / 3.14)).
You can read about it from: http://map3d.wordpress.com/2009/01/29/rotation-of-blocks-or-text/
Kajar
