Infrastructure Map Server General Discussion
wilsonherrera
Message 1 of 4 (1,942 Views)
SQL SERVER SPATIAL COORDINATES FLIP
1942 Views, 3 Replies
08-13-2012 09:56 AM
currentlky i have several layers stored in MS SQL server 2008 if i query them inside sql server management studio, the layers appear normal, but one i try to load them into mapguide, the x and y values swap, creating a 90° map.
this would be a nice feature if you could enable with a click, but this is a bug, and a big one to start, this mean that i can´t really load data from a MS SQL Spatial.
is there a way to fix this? this also happens in map 3D.
this is the layer in MS SQL SERVER
this is mapguide
workaround: store ll coordinates in geography rather than geometry
Valued Mentor
gluckett
Message 2 of 4 (1,868 Views)
Re: SQL SERVER SPATIAL COORDINATES FLIP
09-12-2012 07:20 AM in reply to: wilsonherrera
wilsonherrera
Message 3 of 4 (1,773 Views)
10-09-2012 01:04 PM in reply to: gluckett
its a workaround but it works! thank you!
Valued Mentor
gluckett
Message 4 of 4 (1,361 Views)
12-05-2012 10:01 AM in reply to: wilsonherrera
This BUG has no HOTFIX and is STILL Broken with the FDO 3.7 for the following products:
  • MapGuide Open Source 2.4
  • Autodesk IMS 2013
  • AutoCAD Map 3D 2013
  • Autodesk Infrastructure Modeler 2013
