Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Slow IMS 2012 & SQL Server Spatial
4 REPLIES 4
ced_abitat
628 Views, 4 Replies
  I have a table in SQL Server Spatial containing the points (field type geography with  spatial index set HIGH-HIGH-HIGH-HIGH) and I would like to see them withInfrastructure MapServer 2012. I can view them but it is really slow. If you use the ODBC connection as the display of these points (using X,Y fields) turns out to be much faster. How can I speed up the configuration that uses the SQL Spatial?
I also tried with the 2014 version but does not improve performance
Regards
4 REPLIES 4
in reply to: ced_abitat
Does the bounds of that spatial index cover your area of interest and not the entire planet?
- Jackie
ced_abitat
Hi Jackie,
on Sql Server Spatial only for geometry columns is possible to specify the area of index. I have geography column.
Regards
Matteo
Hi
You may need to generalize your  Lat, Lng coordinates with only 6-7 decimal places
Please let me know if that works or not.
Thanks Smiley Happy
gluckett
First make sure your data is valid:
update mytable
set mygeom = mygeom.MakeValid()
Second, in your layer in Studio, filter out any NULL geometries/geographies
