apologies - it appears that the file is being rejected by the news server.
Perhaps it is too large (15 MB). If you are interested in this file, please
contact me.
"Jon Rizzo" wrote in message
news:5641609@discussion.autodesk.com...
I posted a zip file to the customer files newsgroup with the same subject as
this post. When I try to load this shapefile into MapGuide, Studio crashes.
When I try to load the same shape file in Map, Map crashes as well, but I
CAN import the shape file using the Map->Import command. I suspect that
this is an FDO issue...
Jon
