Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
SessionId Lost while refreshing page
1 REPLY 1
212 Views, 1 Reply
Hi. All, I had made a query page to select the desired polygon by passing the value through the select option , input box etc. it works well but due to amount of data in select option box is large so i fetch the data in the option box from mysql while selecting any item the page gets refreshed i can stored the value of all the field and the query running well but due to the lost of Session Id it can't fire on the map. i had try to re-generate the session Id here but both the Session Id are different. Is There any idea.
Thanking you.
1 REPLY 1
Ask your system MYSQL administrator to reset the sesssion id, it happend most often with all of us..
Cheers!!!
Guide
