Infrastructure Map Server Developer
Valued Contributor
swimming123
Message 1 of 2 (547 Views)
session timeout for AIMS2013
547 Views, 1 Replies
02-20-2013 08:21 AM
when we login Infrastructure Map Server - Site Administrator--> Manager Servers-->Configure Services, we can set session timeout(seconds): 1200. I did a test, set session timeout 60 seconds, then after 60seconds, there's nothing affect for my map dispaly, widgets functions. Can I set somewhere, for example I can close the Map window or Close the Application to match my setting in .NET Global file setting: session timeout, web will log out? Thank you.
Valued Mentor
jackie.ng
Message 2 of 2 (529 Views)
Re: session timeout for AIMS2013
02-21-2013 05:21 PM in reply to: swimming123
You could inject the following javascript into your page
window.setTimeout(<?= $timeout ?> * 1000, function() {
    alert("Your session has ended. Goodbye!");
    window.close();
Where $timeout is the value of MgSite.GetSessionTimeout()
- Jackie
