Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Select specific layer and feature by passing value to flexible layout (AIMS2014)
5 REPLIES 5
reno.sun.gis
1650 Views, 5 Replies
5 REPLIES 5
gluckett
in reply to: reno.sun.gis
I don't think the map.query is implemented anymore.
http://trac.osgeo.org/fusion/wiki/Cookbook/Map/Query
Instead, you may have to use the Web API to select the object, return the Selected XML and use that to highlight and zoom to the obect.
reno.sun.gis
in reply to: gluckett
Finally, I solve my this issue.
I post my solution in the end of the post here: http://osgeo-org.1560.x6.nabble.com/Select-specific-layer-and-feature-by-passing-value-to-flexible-l...
Thank you for your reply 🙂
gluckett
Hi, I put the solution to the auto-zoom to feature on load for Flexible Web Layouts here (http://mapguide.wordpress.com/2013/06/11/autodesk-infrastructure-map-server-auto-zoom-on-load/)
You can pass:
  • LAYERNAME (i.e. Parcels)
  • KEYNAME (i.e. ID or ADN)
  • KEY (ie. 1234 or 444)
  • ISSTRING (0 or 1)
For example, this selects 2 roads in Sheboygan with an ID or 644 and 684:
http://localhost/mapserver2014/fusion/templates/mapguide/slate/index.html?LAYERNAME=Roads&KEYNAME=ID...
The example uses SLATE but it can use any Flexible Web Layout you wish.
Remember, "LOCALHOST" is just a trick to call your own computer as a server, usually you would use the actual name of your server.
reno.sun.gis
For the fusion users, I think this is the simplest solution!
http://autodesk.typepad.com/beyondthebox/2012/09/application-integration-with-autodesk-infrastructur...
If you would like to select features by attribute values 🙂
reno.sun.gis
Moreover, Gordon provided a very neat solution for user would like to select specific layer and feature by primary key too!!!
https://mapguide.wordpress.com/2013/06/11/autodesk-infrastructure-map-server-auto-zoom-on-load/
BTW, I use Gordon's solution for my "Kaliopa Mapguide Mobile Viewer" to allow user select specific features by passing value through the URL.
However, you will face a "zoom to object" issue for point features. Great news is people have already built some solutions for it.
http://osgeo-org.1560.x6.nabble.com/Zoom-to-selected-feature-point-doesn-t-work-td5095926.html
If you're using fusionSF.js like me, you can add the code as following under the renderSelection function:
renderSelection: function (zoomTo, r) {
if (zoomTo) {
var ext = oNode.extents;
//Reno's custom zoom for points
if (ext != null) {
if (ext.minx == ext.maxx) {
this.setExtZoom(ext, 100);
var extents = new OpenLayers.Bounds(ext.minx, ext.miny, ext.maxx, ext.maxy);
this.mapWidget.setExtents(extents);
setExtZoom: function (ext, zoomFactor) {
ext.minx = ext.minx - zoomFactor / 2;
ext.miny = ext.miny - zoomFactor / 2;
ext.maxx = ext.maxx + zoomFactor / 2;
ext.maxy = ext.maxy + zoomFactor / 2;
If you are using "Kaliopa Mapguide Mobile Viewer" with Gordon's solution you will probably would like to add/update following codes under Default.debug.js or Default.min.js:
//Gordon's code
function zoomToObject(sessionId, mapName) {
if (getParam('action' == 'zoom')) {
var SESSION = sessionId;
var MAPNAME = mapName;
var KEY = getParam('KEY');
var ISSTRING = getParam('ISSTRING');
var KEYNAME = getParam('KEYNAME');
var LAYERNAME = getParam('LAYERNAME');
if (KEY != null || KEY != '') {
//The GETSELECTIONXML.php returns the XML of selected features.
var AJAXURL = "/mapserver2014/GETSELECTIONXML.php?MAPNAME=" + MAPNAME;
AJAXURL = AJAXURL + "&SESSION=" + SESSION;
AJAXURL = AJAXURL + "&KEYNAME=" + KEYNAME;
AJAXURL = AJAXURL + "&LAYERNAME=" + LAYERNAME;
AJAXURL = AJAXURL + "&KEY=" + KEY;
AJAXURL = AJAXURL + "&ISSTRING=" + ISSTRING;
var xmlhttp;
if (window.XMLHttpRequest) {// code for IE7+, Firefox, Chrome, Opera, Safari
xmlhttp = new XMLHttpRequest();
else {// code for IE6, IE5
xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
xmlhttp.onreadystatechange = function () {
if (xmlhttp.readyState == 4 && xmlhttp.status == 200) {
SetSelectionXML(xmlhttp.responseText);
ZoomSelection();
MultiGridShow();
xmlhttp.open("GET", AJAXURL, true);
xmlhttp.send();
For zoom problems of point and linear features, modify the code under the ZoomSelection function:
//Modify the extent/zoom level based on your custom needs. You can create some formula for your geographic data :)
function ZoomSelection() {
if (dr.status == 200) {
var env = ParseEnvelope(dr.responseXML.documentElement);
//alert(env.lowerLeft.X + ',' + env.lowerLeft.Y + ',' + env.upperRight.X + ',' + env.upperRight.Y);
if (env != null) {
//var extentSel = new OpenLayers.Bounds(env.lowerLeft.X, env.lowerLeft.Y, env.upperRight.X, env.upperRight.Y);
var sc = (env.upperRight.X - env.lowerLeft.X);
if (sc == 0) {
var pointextentSel = new OpenLayers.Bounds(env.lowerLeft.X, env.lowerLeft.Y - 40, env.upperRight.X + 10, env.upperRight.Y + 10);
var cntL = new OpenLayers.LonLat(env.lowerLeft.X, env.lowerLeft.Y);
map.setCenter(cntL, 1);
map.zoomToExtent(pointextentSel);
else if (sc < 10) {
extentSel = new OpenLayers.Bounds(env.lowerLeft.X, env.lowerLeft.Y - 50, env.upperRight.X, env.upperRight.Y);
map.zoomToExtent(extentSel);
map.zoomToScale(2500, true);
else {
