Infrastructure Map Server Forum
Welcome to Autodeskā€™s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Showing results forĀ
Did you mean:Ā
SDFLoader and AutocadMap 2004 dwg
2 REPLIES 2
196 Views, 2 Replies
I've just updated my autocad map software to the latest 2004 version. I
realized that the the new dwg format file is quite diferent from the
previous ones. So far so good, as long as there is compatibility. But, on
using the MapGuideĀ“s SDF loader (version 6.0) on these new dwg format
files, it seems that it does not recognize them. I must open the drawing
files, save them as the previous 2000/2002 version, and only then the SDF
loader can recognize the format.
Is there a new version of the SDFLoader comming soon?
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.504 / Virus Database: 302 - Release Date: 24-07-2003
2 REPLIES 2
SDFLoader 6.3 that came out in May with MapGuide 6.3 should be compatible
with 2004 flavor DWG files. Check with your reseller for information on how
you can upgrade.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.spatialgis.com
"TVK" wrote in message
news:275718E96C6D68A6814521EB09B18C87@in.WebX.maYIadrTaRb...
NOSPAM,
You can download the Autodesk MapGuide SDF Loader 6.3 from:
http://www.mapguide.com/Downloads/MG_R6.3/En/SDFLoader/MGSDFLoader63.exe
This version supports DWG 2004 format.
Chris L. Amos
Autodesk MapGuide Quality Engineering
