Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
SDF Loader for AutoCAD 2010 version of drawing
1 REPLY 1
wesbird
822 Views, 1 Reply
HI,
  I'm migration my tool of SDF Loader to work with AutoCAD 2010. I got this error message,
    Error : Unable to load data. Please check the input filename and format.
  Does SDF Loader 6.5 sp1 work with AutoCAD 2010 version of drawing?
  if not, is there any tool I can use to generate SDF 2 file?
  if yes, is there any API so I can programming with it? VB6, .Net (VB.Net or C#), AutoLISP or ObjectARX ?
Thank you,
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
1 REPLY 1
AlbertKalman5692
in reply to: wesbird
The sdf loader sp1 works with 2007/2008/2009 dwg version. For 2010 you need to save the dwg  in the previous version.
Kalmy
