style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"bzc" <Dear
href="mailto:bcarroll@geodecisions.com">bcarroll@geodecisions.com>
wrote in message
href="news:f10ea7a.-1@WebX.maYIadrTaRb">news:f10ea7a.-1@WebX.maYIadrTaRb...
All,
It appears that SDF converter in many AutoDesk products doesn't work
well to say the least especially if your writing out attribute information
from a linked data source. AutoDesk is unable to achieve this functionality
and your better off switching software vendors. One would think this would be
easy seeing that both file types are proprietary AutoDesk formats. I've spoken
with AutoDesk people and they are aware of the problems but are unable to
offer any solutions. It's unbelievable.
"bzc" <We
wrote in message
href="news:f10ea7a.1@WebX.maYIadrTaRb">news:f10ea7a.1@WebX.maYIadrTaRb...
have a parcel dwg linked to an acces database through a template. The database
stores the attribute info. This works well enough. You can select a parcel and
hightlight the link in the database....conversely you can select a record in
the database and zoom to the parcel. We've been attempting to convert the dwg
to sdf and write ID field stored in the database to the KEY field in the sdf.
We've tried using Map and Land Desktop but it either crashes without returning
an error or only writes half of the parcels the
fails.
"Scott Friedrich" <
href="mailto:scott.friedrich@techsoftware.com">scott.friedrich@techsoftware.com>
wrote in message
href="news:D83D8B3D01D8DD462BC2F14A0C655B5E@in.WebX.maYIadrTaRb">news:D83D8B3D01D8DD462BC2F14A0C6......
Does it bomb using the SDF Loader as
well?
Scott
"bzc" <We
wrote in message
database stores the attribute info. This works well enough. You can select a
parcel and hightlight the link in the database....conversely you can select
a record in the database and zoom to the parcel. We've been attempting to
convert the dwg to sdf and write ID field stored in the database to the KEY
field in the sdf. We've tried using Map and Land Desktop but it either
crashes without returning an error or only writes half of the parcels the
fails.
"bzc" <Dear
wrote in message
All,
