I use SDFLoader converted a shape file to SDF file without any error message. Then I try to use SDF Component toolkit to change some attribute of the objects in SDF file. I keep getting error '0x80041016 sdfPolygonUnclosed', is there anyone know what cause it happen? What should I do to fix it?
If the map data is not correct, why I don't have problem with converting shaping file to SDF file?
