Does anyone know is it possible define SDF attribute property field as link for URL so I can click on url address in selection tab and I can go directly to webpage. There is no such Data type in property filed like URL.
Create a calculated property with an expression based off of URL that creates a HTML anchor.
Something like:
Concat('<a href="', URL, '">Click here</a>')
The property grid should interpret that value has HTML content and display a link for you.
- Jackie
Jackie,
I tried your suggestion, but did not get it to work.
My selection panel is showing it as a simple text, however the New Calculation under SDF data preview is shown as a link
See Attached Images.
Any ideas?
Thank you,
Svet
It is most likely being escaped. That is, looking at the source you'll see this:
instead of:
- Jackie
I figured out the problem, with Basic Layout link stuff is working well, but with Flexible its not working, there must another way to define link.
Kajar
This is kinda an old thread but has anybody figured out how to get this to work in Fusion?
I have a link to an image that I would like to get to work without haveing to copy and past it in a browser. Any suggestions are warmly welcomed.
This solutions worked for me: http://osgeo-org.1560.x6.nabble.com/Hyperlink-in-Selection-panel-tp4984293p5033778.html
I just did a quick test wtih AIMS 2015 and added a "Calculation" in the Feature Source and it worked fine.
