Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Running MG OS on Windows XP Pro
2 REPLIES 2
BillPowell
249 Views, 2 Replies
Using Mapguide Open Source I am using the following configuration:
Windows XP Pro with Apache
Everything runs on this box
I have read in the documentation that only Windows 2000 & 2003 Servers are supported. However with the limited use Ive had so far, everything seems to be running fine using XP Pro as an OS. Is there any big gotchas with this setup, keeping in mind this is for development only. Or is anyone using any lightweight free virtual servers to get past this limitation.
2 REPLIES 2
in reply to: BillPowell
This is mainly because of the connection limits in Windows XP. It's
just not a server operating system, and IIS is crippled on it (Andy
added a way of getting around that well enough for development here:
http://wiki.osgeo.org/index.php/MapGuide_Open_User_Technical_FAQ%27s )
but given that you're running Apache you should be OK... at least for
development.
For a production site, you'll want to be running it either on Linux or
on Win 2k3. Apparently performance is marginally better on Linux.
For questions about MapGuide OS, you're likely to get better response on
the OSGeo MapGuide Users mailing list.
Jason
BillPowell
Thanks for the reply Jason.
I think I will start posting my questions on the OSGeo mailing list, especially since it its taking autodesk so long to split the Mapguide forums here.
Cheers
Bill
