I have an asp site that loads a base map. In the menu system I have links to all my layers. The user can turn off & on layers via the menu. This is all done with JavaScript & the Map API. This is where I get a little confused. Depending on what layer the user has turned on is there a way to add a report dynamically to the base map & then call GetMap().viewReportsDlg() to show the user what reports are available?
Any help would be great…Thanks
