Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
remove "Autodesk" banner in viewer
10 REPLIES 10
Message 1 of 11
spadana
770 Views, 10 Replies
i want to remove "Autodesk" banner in viewer .
how can i do ?
help me plz
10 REPLIES 10
Message 2 of 11
Guide
in reply to: spadana
hahaha what a ?, are you planning to add your companies logo instead?
Remember i doubt if such thing is possible, may be i would suggest you to get help from Autodesk technical support to check this,
Cheers!!!
Guide
Message 3 of 11
spadana
hahaha
I solve this problem without help from Autodesk technical support ,
I Find the attractive solution ...
Message 4 of 11
Guide
wow, would you share with us.
What you did to remove autodesk banner in Viewer?
Message 5 of 11
gingerbbm
It's referenced in a .templ file. Just find it and remove it!
Message 6 of 11
Guide
Hi gingerbbm.
Thanks for your response.
I have searched the system for .templ but couldn't find, can you please help me how to find that.
Guide.
Message 7 of 11
gingerbbm
Apologies. I knew my post was lacking in detail but I was away from my work machine so didn't have access to the file system.
Anyway, this is where you'll find it:
c:\Program Files\Autodesk\MapGuideEnterprise2009\WebServerExtensions\www\viewerfiles\statusbar.templ
Scroll to the bottom of the file and you'll see the reference.
BTW, I'm talking about MapGuide 2009.
Hope this helps
Cheers
Stuart
Message 8 of 11
spadana
hi Guide
find MgAxCtrl.dll in the path that install MapGuide, for example
C:\Program Files\Autodesk\MapGuideViewerActiveX6.5
then open this dll with visual studio.net , then Edit that,
note you must first copy this dll in othere place and after edit it ,replace it in the base path.
Message 9 of 11
ynking
Thanks! This works for me. Just replace the image name in the following code:
or replace the "PoweredBy_en.gif" image with my own one.
Message 10 of 11
Before removing/replacing elements of Autodesk Software, it is advisable to
insure that there are no Copyright/License infringements by doing so.
Chris L. Amos
Quality Assurance Autodesk MapGuide
wrote in message news:6045309@discussion.autodesk.com...
code: or replace the "PoweredBy_en.gif" image with my own one.
Message 11 of 11
gingerbbm
Chris, your message implies that you work for Autodesk. If this is true, perhaps you could advise on the copyright/license position regarding changing the logo in the Ajax viewer?
Stuart
