Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Raster Time Outs
2 REPLIES 2
hhiggins
223 Views, 2 Replies
Raster Time Outs
Howdy,
Try to add a raster image to MapGuide and am having time out issues. I've uploaded 2 other raster images with no issues. The image is 1.6GB. I see the errors when I am in a Load Procedure and select "Load Resources". This is how I did the other 2 and it worked. Is this image too large or is there a better way?
Thanks!
2 REPLIES 2
dswilson
in reply to: hhiggins
In MGE 2008 and later you can use Unmanaged connections which allows you to set up folders on the server, define an alias to the folder and use that alias in a connection in Studio. The aliases are set up in the Site Administrator.
Your timeout could be related to several things including a PHP timeout when loading the package (that's what a load procedure does). Packages are also limited to 2GB.
Dave
hhiggins
this worked perfectly. thanks!
