Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
"URL activated for feature" link
3 REPLIES 3
828 Views, 3 Replies
I'm trying to link some features in the map using the "URL activated for feature" in the layer editor. (MGE08, IIS)
if I put www.google.com, then clicking on the map links to http://xxx/mapguide2008/mapviewerajax/www.google.com
How can I remove the first part of the url? Why does it include it? Also, where can I change the setting for how I want the url displayed (new window, new tab, same window etc).
thanks,
-Mike
3 REPLIES 3
www.google.com is not a url 🙂 Ok, it might be, but only in the context
that MapGuide (or more likely the web browser) is interpreting it: as a
relative url. You would see the same results if you used www.google.com
as the value of the href attribute in an HTML anchor (a) element.
You need to include the http:// part for it to work, and should really
include the trailing slash as well.
Back in the old days, browsers did not allow you to get away with typing
the host name without specifying the protocol... then they clued in and
assisted the users (and marketers) by making the assumption that most
users of web browsers actually want to see a web site.
Jason
Thanks Jason, that worked just right.
hi, I am using Mapguide Studio 2010. I want to add a link on my map on a specific spot. How Is it possible to add a button/text and assign a url to it?
Thanks in advance
P.S. the link is intendet to be external (not on the same server)
