Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
"Flexible Web Layout Example 2: Selections" generates error
1 REPLY 1
dajvid
1404 Views, 1 Reply
I'm testing "Example 2: Selections" in the "Flexible Web Layout Examples":
http://wikihelp.autodesk.com/Infr._Map_Server/enu/2013/Help/0005-Develope0/0105-Flexible105/0112-Exa...
Testing the Example2.js provided, a javascript error is generated on the following line:
var oSelection = selection[theMap.getMapName()];
The error generated is:
Fusion Error:
WARNING: Exception occurred in AJAX callback.
Message: getMapName is not a function
The same code appears in
http://wikihelp.autodesk.com/Infr._Map_Server/enu/2013/Help/0005-Develope0/0094-Flexible94/0100-Work...
What is the correct code for working with selections?
Kind regards,
Dave.
1 REPLY 1
jackie.ng
in reply to: dajvid
Oh dear! Someone changed the API and failed to document this!
Anyway, here's how you can get the map name.
//Gets the MapGuide map name from the map widget
//theMap: The Fusion.Widget.Map instance
function getMapName(theMap) {
//subMaps will be an array of Fusion.Layers instances (of which Fusion.Layers.MapGuide is a subclass of) var subMaps = theMap.getAllMaps(); for (var i = 0; i < subMaps.length; i++) { if (subMaps[i].arch == "MapGuide") { //Is a Fusion.Layers.MapGuide object return subMaps[i].getMapName(); //Map name is here } } return null; }
Unless you have some strange multi-map setup, the subMaps array will generally have at most one Fusion.Layers.MapGuide instance, so you just find that instance (using the .arch property to determine the correct sub-type) and get the map name from that instance.
 - Jackie
