Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
QuickPlot on HTTPS
0 REPLIES 0
Message 1 of 1
624 Views, 0 Replies
QuickPlot on HTTPS
When I wan't to use QuickPlot I get error:
The application resources required to generate the plot exceed the settings defined by the administrator
This problem only occurs when I connect through HTTPS. It's working correctly on HTTP.
Do you have any idea what is causing this?
0 REPLIES 0
