Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
QuickPlot file IO file Exception on AIMS 2014
2 REPLIES 2
uzzal46bd
1165 Views, 2 Replies
I have a problem on our server with QuickPlot on AIMS 2014. After generating the pdf it was written on the pdf that: Last error Error: A file IO exception occoured in: C:/Windows/Temp/mgo516b52b0e030.
I have attached the error generated pdf on the attachment.
I think this problem happens because I have uncommented -----session.save_path = "/tmp"---- on php.ini file  (This php.ini file is available on AIMS 2014's webserver Installation folder/php folder)
I have uncommented the  session.save_path = "/tmp" because without that one Fusion layout cannot start or it cannot create session. Because I think it cannot create session data on C:/Windows/Temp folder (by default) because of permission issue. I have given full control on C:/Windows/Temp folder but it doesn't help. Then I have tried with Uninstalling AIMS 2014 and reinstalling again but it doesn't help as well.
I didn't tried with uninstalling IIS and reinstall it again because we have some other application available on IIS.
Without uncommenting session.save_path = "/tmp" and trying to connect site administration show login error or fast-cgi process exited unespectdly.
I think this is all about permission issue on C:/Windows/Temp folder. Because now on our AIMS 2014, it is created session data file on C:/tmp folder but may be Quickplot is trying to find the the session data file on C:/Windows/Temp folder or may it tries to create some file on C:/Windows/Temp folder which it cannot make because of Permission Issue.
So, can you please suggest what can be done to solve that problem.
Thanks in advance.
Best Regards
Mohammad
2 REPLIES 2
By default QuickPlot use the system temporary directory.
The temp directory can be changed in GeneratePicture.php (www\fusion\widgets\QuickPlot\) around line 122:
$tempImage = sys_get_temp_dir() . DIRECTORY_SEPARATOR . "mgo" . uniqid();
Bernhard
Hi Bernhard,
Thanks a lot. I have changed that and it is working.
Best Regards
Mohammad
