Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Question Marks in Legend
1 REPLY 1
675 Views, 1 Reply
Team,
I am programatically adding a new Layer to the MapGuide and then refreshing the Map.
But for some reason the Legend is not refreshing. It simply shows question marks (snapshot attached).
Again sometimes it shows up and sometimes it does not.
Any thoughts what would cause this ?
Thanks for your time.
Regards
Anand
1 REPLY 1
Hi Anand,
I will suggest you try applying the MapGuide Enterprise 2010 ( I presume you are using 2010 version) Updates / service pack and see if that helps in resolving this issue.
You can get the service packs / updates from the following link -
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242179
HTH,
Partha Sarkar
