Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Property information related to Fusion
2 REPLIES 2
swimming123
1367 Views, 2 Replies
When I read the js in the fusion/widgets folder, I found these properties' name: for example this.sTarget, this.sBaseUrl, this.bSelectionOnly.... In the xml file I also found these names like <Name>DisableIfSelectionEmpty</Name>. So how I can find all these propertyies, names and their detail explaination? Thank you.
2 REPLIES 2
jackie.ng
in reply to: swimming123
You can find information about widget extension properties for a particular widget by looking at the matching XML documentation file under widgets/widgetinfo
- Jackie
swimming123
in reply to: jackie.ng
Thank you Jackie, matching XML file has parameters content for some of properties. When I should create the parameter content for these properties or should I create for all the properties in a specific widget? XML file has to matching with the corresponding js file? How to validate this kind of matching?
