Infrastructure Map Server Developer
Valued Contributor
1 Kudo
Post 1 of 3
Property information related to Fusion
1167 Views, 2 Replies
06-06-2012 09:28 AM
When I read the js in the fusion/widgets folder, I found these properties' name: for example this.sTarget, this.sBaseUrl, this.bSelectionOnly.... In the xml file I also found these names like <Name>DisableIfSelectionEmpty</Name>. So how I can find all these propertyies, names and their detail explaination? Thank you.
Valued Mentor
24 Kudos
Post 2 of 3
Re: Property information related to Fusion
06-06-2012 07:06 PM in reply to: swimming123
You can find information about widget extension properties for a particular widget by looking at the matching XML documentation file under widgets/widgetinfo
- Jackie
Valued Contributor
1 Kudo
Post 3 of 3
06-06-2012 08:39 PM in reply to: jackie.ng
Thank you Jackie, matching XML file has parameters content for some of properties. When I should create the parameter content for these properties or should I create for all the properties in a specific widget? XML file has to matching with the corresponding js file? How to validate this kind of matching?
