Is there a way of having the Display Projection set to UTM and have the units set to meters. Currently the map is mercator as I am running BING layers.
I have tried this within the layout:
<Name>StatusCoords</Name>
<Type>CursorPosition</Type>
<Extension>
<Template>x: {x}, y: {y}</Template>
<Precision>4</Precision>
<DisplayProjection>EPSG:3776</DisplayProjection>
<Units>m</Units>
</Extension>
</WidgetType>
The 3776 is a 3TM projection for Calgary, Alberta. I get an error when the map loads. The error is an exception occurred in AJAX callback. Unable to get value of property 'toLowerCase': object is null or undefined.
If I cancel the error message, the coordinates read correctly but all the toolbar commands are turned off/not active.
