Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Projection to be changed to UTM and have units set to meters
0 REPLIES 0
Message 1 of 1
406 Views, 0 Replies
Is there a way of having the Display Projection set to UTM and have the units set to meters. Currently the map is mercator as I am running BING layers.
I have tried this within the layout:
<Name>StatusCoords</Name>
  <Type>CursorPosition</Type>
  <Extension>
    <Template>x: {x}, y: {y}</Template>
    <Precision>4</Precision>
    <DisplayProjection>EPSG:3776</DisplayProjection>
    <Units>m</Units>
  </Extension>
</WidgetType>
The 3776 is a 3TM projection for Calgary, Alberta. I get an error when the map loads. The error is an exception occurred in AJAX callback. Unable to get value of property 'toLowerCase': object is null or undefined.
If I cancel the error message, the coordinates read correctly but all the toolbar commands are turned off/not active.
0 REPLIES 0
